2 Wheel drive powersteering hoses
Discussion in 'The Garage' started by bajaviking, Jan 26, 2007.
  1. bajaviking
    bajaviking 1/2 ton status
    Apr 10, 2002
    752
    Baja
    I am doing the croosover and I think I got a steering box from an older model, my Blazer is an 82 and the fittings on the powersteering hoses don't fit. If I get new hoses for a truck from an older truck will they fit in my pump or do I need to change the pump to an older style also?
  2. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Are the ends of the hoses flared or do they have a tip with an oring on them. If they are Oring then you need to get flared hoses and change the fitting out on the pump to be a flared fitting. I would go to the junkyard and just pull the fitting from a pump there and replace yours. No need in buying a whole new pump just for a fitting. Oh you would need to get new hoses also.
    Ira
  3. big dan
    big dan 1/2 ton status Premium Member
    Aug 1, 2005
    2,656
    29
    Arkansas
    can you get the fitting from the parts store? or do I need to get it from the yard? Im in the same situation and was fixin to go get the new hoses till I red this.
  4. sandawgk5
    Oct 28, 2003
    6,881
    If your hose wont fit the steering box then you need new hoses anyhow. The problem is there is not a hose that is oring on the pump and flare on the box. You can have them custom made but they are $$$. I have not looked for the fitting in the store but I would have to say they do not carry them.
    Ira
  5. big dan
    Aug 1, 2005
    2,656
    29
    Arkansas
    Ill check when I go. I didnt know that the pumps had different fittings, I always thought it was just the box that took different fittings. thanks.
  6. sandawgk5
    Oct 28, 2003
    6,881
    Yep when the box went to Oring fittings so did the pump. Not sure if they had hydroboost before 1980 but the fittings on the Hydroboost unit are oring also.
    Ira
