2 wheel drive steering box nut
Discussion in 'OffRoad Design' started by Jishory, Mar 10, 2005.
  1. Jishory
    Jishory 1/2 ton status
    Jan 8, 2002
    1,367
    Palmdale, CA
    I just installed the ord crossover system and i need to know what is the name of that nut that you use to keep the pitman arm on the steering box and if you guys stock them
    thanks
  2. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    I doubt ORD stocks them as it is a factory part. I've been told that a pinion nut from a D60 is the same size and is thicker therefore has more thread engagement.
  3. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    That should be a standard 7/8-14 jam nut. This is a normal fine thread so there's a good chance you can find one in the bins at a good hardware store. Often heavy equipment dealers have stuff like this floating around too. If you're ordering something from here, we can get you one in the order but it's probably not worth the shipping to send one alone.
