20 gallon RCI fuel cell with fuel foam, PIC added! NEW PRICE
Discussion in 'General Parts for Sale' started by juanblzer, Aug 21, 2004.
  1. juanblzer
    juanblzer 1/2 ton status
    Sep 12, 2001
    1,614
    9
    Chandler, Arizona
    $150 obo
    Prefer not to ship (isn't it illegal to ship fuel tanks that have already had fuel in them?). Prefer AZ customers only.
    As described:
    This is an aluminum RCI 20 gallon fuel cell with built in sump. I have a large square inspection plate that is tapped four small machine bolts that holds a YJ sending unit bracket that is modified to accept a stock GM in tank fuel pump. The pump does not come with it. This pump bracket allows the pump to sit in the sump with it's sock. By the way it never leaks off of my inspection plate. THe only proplem I had with this cell is I had a hairline crack on one of the welds on this fuel cell but I just paid to have it repaired by a very reputable aluminum welder for $100. I can provide the reciept for repair if necessary.
    It also comes with a 0-90ohm fuel level sender.
    My reasons for selling this cell:
    too small for Baja excursions and adventures that require lots of miles on the highway
    I need more weight (I'm going 30 gal. over my rear axle) for stability offroad and to allow the coilovers to work well.
    I want to run baffles and no foam with a tricky sump that will allow me to not have fancy pickups.
  2. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Re: 20 gallon RCI fuel cell with fuel foam, & mounting bracket for GM fuel pump
    pm sent...
  3. juanblzer
    Sep 12, 2001
    1,614
    9
    Chandler, Arizona
    Re: 20 gallon RCI fuel cell with fuel foam, PIC added!
    ttt
  4. juanblzer
    Sep 12, 2001
    1,614
    9
    Chandler, Arizona
    bump
  5. juanblzer
    Sep 12, 2001
    1,614
    9
    Chandler, Arizona
    new pic added
  6. juanblzer
    Sep 12, 2001
    1,614
    9
    Chandler, Arizona
    ttt
    new price
