200 amp altenator
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ftn96, Dec 19, 2001.
  1. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    I've looked at altenatorparts.com and powermaster's and found 2 200 amp altenators that supposedly bolt right up to my year model. Are they any down falls to running a 200 amp alty?
    Still hoping the GOV'T will ban the use of loud stereos with RAP music. [​IMG]
    <a target="_blank" href=http://www.nashvillek5.freeservers.com>www.nashvillek5.freeservers.com</a>
  2. ricka
    ricka Registered Member
    Nov 24, 2001
    40
    Beaverton, Oregon
    Expensive is the major shortcoming. But as you increase amperage, you generally
    develop more heat and thus reliability might be an issue.
    Rick Anderson (rick.d.anderson@tektronix.com)
    Tektronix, Inc. Beaverton, OR 503-627-2630
  3. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    Makes since. I have seen others on here advertising that they run lights, winch, stereo and the regular stuff on 140 ampers.
    Is this common? If so the 140 amp one is about 100 bones cheaper
  4. 502Burban
    502Burban 1/2 ton status
    Jun 8, 2001
    379
    Southern California
    Be careful about the "bolt right in" claim. I have one of the Powermaster 200 amp alts, which they claimed would "bolt right in" to my bracket setup from a '94. It was close, but not quite. However, the mods were easy: all I had to do was drill one of the mounting holes to a bigger size and egg-shape it a little to get it to fit.
    The other fitment issue is that the 200 amp alt is deeper, so it comes very close to my valve cover. I can't even slip a finger between them, but it does clear.
    There are pics under the engine section of my webshots site (at the link below my sig) if you want to take a look.
    Robb
    <a target="_blank" href=http://community.webshots.com/user/robbrj>'73 GMC Suburban - 502DFI</a>
  5. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    Yup the bolt right in claim is kinda tough, My 180 amp alternator needed an adapter for the harness and then I had to fab up the bracket a little. One word of warning if you have a serp style pulley you will have to swap pulleys as the 140 comes with a V belt pulley. This left my truck a bit lower at idle then the original setup, but by the time youget up to 800 rpm's she was charging like mad!
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <a target="_blank" href=http://coloradok5.com/gallery/captcrunch>http://coloradok5.com/gallery/captcrunch</a>
  6. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    I think the one I found at altenatorparts.com has the serp pulley. And as far as capatability it says its for 86-90 something or another. K-series included.
  7. Skigirl
    Skigirl 1/2 ton status
    Apr 2, 2001
    2,563
    Los Angeles, California
    Add up the amps for what you would potentially be using all at once, then get an alternator that has 25% more amperage than that. That was the sage advice given to me by Gandolf (as I recall). I think there's a good reason for that. You don't want your alternator to overcharge your battery, so bigger is not always better. You just need enough alternator to get the job done.
  8. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    Yep, I ran into the same problems with my "bolt in" 200 amp alt, like 502 said. I did the exact same things he did as well to fix it. Had to tie my radiator hose and move it away a little too, to get it from getting sliced up by the alternator pulley. I love the 200 amp though...recharges my batts sooo fast!! (very noticable when winching)
    Boss
    Pic of my truck Before N' After
    <a target="_blank" href=http://coloradok5.com/gallery/BeforeNAfter>http://coloradok5.com/gallery/BeforeNAfter</a>
  9. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    Well, here is the deal. I called altenatorparts.com and got the delco CS144 Dual Rectifier 170 amp setup. Comes with the serp pulley. And they offer a rebuild kit that can be performed even by an idiot on the side of the road or trail with basic tools.
    The Damage was $300. The sad thing is, that I wont be using all that power for at least another year due to all the other stuff Im rebuilding. So I shouldn't have to worry about it having any problems charging my battery. [​IMG]
  10. CrazeeBush
    CrazeeBush 1/2 ton status
    Apr 17, 2000
    464
    Middle Tennessee
    So, now you got enough power to juice 20 15" subs with a 1000 watt amp for each. When the power goes out, just plug your truck into the house and start 'er up. lol
    -BuSH
    '83 K5 Blazer
    '98 Monte Carlo z34
  11. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    lmfao!!! Yeah that or when the I run outta plugs for all the Christmas light! (that I dont have). I've seen few around the hood that look like they may need a permit to be pulling all that power. Or 10 extra generators!!! [​IMG]
    And we be only putting in 2 subs and a we little amp.
    And no off-road lights other than a Spot light. So most of this iwll be for the winch and what ever the motor needs. So I should have plenty of "head-room".
  12. rampage
    rampage 1/2 ton status
    Mar 20, 2001
    2,260
    72
    Humboldt/Pacifica, CA
    <blockquote><font class="small">In reply to:</font><hr>
    <hr></blockquote>
    I didn't think it was possible to overcharge your battery unless your alternator was bad.
  13. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    As long as the voltage regulator is good I dont see how you can over charge it.
