2000 gmc jimmy dtr lights acting up HELP!!
Discussion in 'The Garage' started by bad_bo_ti, Jan 26, 2004.
  1. bad_bo_ti
    bad_bo_ti 1/2 ton status
    1,027
    OhiO
    my girlfriend has a 2000 gmc jimmy and she was following me the other day in it and when she turned on her turn signal (either side) the day time running lights went out?!?!? /forums/images/graemlins/confused.gif /forums/images/graemlins/eek.gif and after she turned they came back on!!! is it suppose to do this? if not what the HE!! is wrong with it!! i have not checked any fuses yet but all the lights and accessories seem to be working. thanks, chris
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    daytime running lamps are generally the highbeams with less current applied to the circuit.. check out to see if when you turn the headlamps on, try the highbeams, i bet they dont work, and if they dont, you'll need a multifunction switch..
  3. bad_bo_ti
    1,027
    OhiO
    thank you for the reply, is that the name of the switch, multifunction, will the stealership i mean dealership know what i am talking about!!! are these things pricy???
  4. Confedneck
    Nov 1, 2002
    5,236
    yes thats the name of it, its what controls the blinkers, wipers, high beams, flash to pass, and cruise control on these things.. possibly the flashers as well..
    it will probably be a little pricey, say oh around 180$??
  5. bad_bo_ti
    1,027
    OhiO
    oh joy my girlfriend is going to love the sound of $180!!! thanks, i will have investigate it the next time i get a chance.
