2000 sub ABS issue
Discussion in '1936-Present Suburban' started by cegusman, Mar 12, 2006.
  1. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    The ABS pump/module stays running and whining when the sub is shut off, Pulled the fuse for the abs and it shuts off. Can't find any relays for it to replace. Any idea what would cause this?
  2. oldtoyboyd
    oldtoyboyd 1/2 ton status
    Nov 12, 2003
    904
    3
    Leesburg, MS
    Normal problem on the new body style trucks. Unfortunately the cure is to replace the abs pump motor assembly because the relay that is bad is an internal non replaceable part.
    Daniel
  3. 84zz4ss
    84zz4ss 1/2 ton status Premium Member
    Dec 28, 2004
    1,342
    Pensacola FL
    You can replace just the brake control module. But prepare to unload your wallet.
