2000 wheels on an 87?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Rolled, Aug 12, 2002.
  1. Rolled
    Rolled 1/2 ton status
    Jun 16, 2002
    683
    Anchorage, Alaska
    Hi everybody
    I am looking into purchasing some wheels off a 2000 Suburban to put on my 87K5. I was told the offset is different buy one guy and they would not fit but another guy said its true the offset is different but he has swapped them over with no trouble.
    Who is correct here? I want new style rims (92 to 02) but am unsure if the will fit :-(
    Here is what I have to work with:
    1987 K5
    4 inch lift
    10 bolt front and rear
    35 - 12.5 tires
    Some after market locking hubs in the front (not sure if that is relevant)
    Any response will be appreciated.
    Rolled
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Offset aside, I don't think that the centers of the newer wheels are large enough for the hubs on the old trucks to come through... </font color>
  3. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    Not sure about the center holes, but the backspacing is different - ~5 1/2" for the new stuff ('88 and up), and
    ~3 1/2" for the older stuff ('87/'91 and older)
  4. 4x4Freak
    4x4Freak 1/2 ton status
    Apr 21, 2002
    792
    Lubbock, TX
    The bolt pattern is the same, but the center hole is too small to even fit on the back axle. It might be possible to have a machine shop or someone cut the center out enough to fit.
  5. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    i'm sure it'll fit on ther back axle...I see 80's 2wd Burbs with 90's rims on them everyday, still, the 4wd ones won't work cause of the hubs...
  6. Rolled
    Jun 16, 2002
    683
    Anchorage, Alaska
    Thanks guys
    I guess I'll go the aftermarket route.
