2001 2wd to 4wd any ideas?
Discussion in 'The Garage' started by stout87k5, Mar 10, 2007.
  1. stout87k5
    stout87k5 Registered Member
    Feb 19, 2007
    21
    ne washington
    so ive got a 2001 gmc 2wd ext. cab im thinking about converting to 4wd, 2wd just dont cut in the snow. im thinking its got a 4l80e bolted to my 4.8 just have not crawled under to check yet.would i have to change trans? would my 208 from my 87 jimmy bolt to the 4l80e?or would i have find a 4wd version?any one done this conversion before? please post up any ideas or feel free to correct me on the type of tranny i might have.
  2. stout87k5
    Feb 19, 2007
    21
    ne washington
    any ideas?
  3. skyyk5
    skyyk5 1/2 ton status
    Jan 2, 2007
    1,537
    N.E. PA
    I have seen new Chevy vans converted to 4x4. they use a driver drop t-case, and driver drop (f*rd) solid axel.
  4. stout87k5
    Feb 19, 2007
    21
    ne washington
    i was hoping to keep it cheap by using my ten bolt and 208. well short of cheap
  5. skyyk5
    Jan 2, 2007
    1,537
    N.E. PA
    Well you have a 2x4 trans. I think you would have to swap out the output shaft to bolt on a t-case. Thats $! I'm really not sure, Don't mess with auto's that much.
  6. skyyk5
    Jan 2, 2007
    1,537
    N.E. PA
    I would say find a donor trans/t-case. Prob. the easy way to go.
  7. stout87k5
    Feb 19, 2007
    21
    ne washington
    what about 700r4 think it would bolt to my 4.8?
  8. skyyk5
    Jan 2, 2007
    1,537
    N.E. PA
    Didn't they change the bell bolt pattern alittle? I forget. I try not to touch my 03 sierra, too new. LOL
  9. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,228
    485
    New Hampshire
    I wouldn't bother in converting such a new truck. I would trade it in for a 4x4 truck of the similar year and mileage with similar options, or maybe upgrade a few...
    You should have no problem finding a newer truck like the one you have in 4x4.
  10. stout87k5
    Feb 19, 2007
    21
    ne washington
    not sure about the bolt pattern i would have to look.i try not mess with the 01 to much ether, i got my jimmy for ''gitten my wrench on '' but i like the truck ive got dont want trade it in
  11. W7NB
    W7NB 1/2 ton status
    Nov 9, 2006
    716
    Springtucky, OR
    If you have to ask the question don't waste your time. The money you will spend on the conversion will far exceede the cost to sell your truck and buy a similar 4X4. I've seen several butcher jobs that were never right after finished - driveline issues, steering geometery problems you name it. Or keep the 2wd and get an older 4 wheeler you won't mind getting dirty and getting out to play with:laugh:
  12. stout87k5
    Feb 19, 2007
    21
    ne washington
    plus i like the solid axle over that new junk.i was also wondering if a shackle flip would work on my rear leafsprings?
  13. AJMBLAZER
    AJMBLAZER Better to be lucky than good. Premium Member
    May 18, 2000
    22,792
    100
    Paducah, KY
    What he said. 4x4 conversions aren't cheap or easy on GM's.
  14. 85mudbogger
    85mudbogger 1/2 ton status
    Feb 5, 2007
    226
    missouri
    why not a divorce t case then u just a a solid axle up front and a front and rear shaft and keep ur trans, there are 3 trucks runin around town with the sa in front and one is runin the divorce and its bad, 454 with like 8 inches and 39.5 boggers, its not hard to do the sa front, many write ups on this all over the mags
  15. FOR MUD
    FOR MUD 1/2 ton status Premium Member GMOTM Winner
    Apr 6, 2006
    2,801
    387
    Clayton Del
    What you are asking is not the easiest thing to do right, even for people who have the knowledge and the right tools to do the job. Judging from what you said, I think you should sell what you have and buy a 4x4, or pay someone with experience with this kind of swap to do the job.
    Just my two cents.
  16. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    you have a 4L60E if you have a 4.8L. the 4L80E came behind the 6.0L. the easiest way to convert your truck to 4wd is to trade it in on a 4wd.
