2002 Sunfire 2.4L question
Discussion in 'Other Rides' started by 88K5Jimmy, Nov 18, 2004.
  1. 88K5Jimmy
    88K5Jimmy 1/2 ton status
    Jan 10, 2001
    1,323
    Tulsa OK
    I have a friend that has a 2002 sunfire with the 2.4L twin cam motor. It runs and idles really rough and the exhaust smells like its running rich with a lot of carbon monoxide smell. The check engine light finally came on after a couple of days of it running rough, etc. Is there a way to short the computer port like in our trucks and get a code? Also, where the heck is the distributor on that thing?
  2. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    as far as i know there isent a Dist. on it, it should have coil on plug like all the newer chevy motors.
  3. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    that would be the OBDII, you need a code scanner to get a code. autozone will do it for free.
    gm hasn't put a distributor in a front wheel dive car since 89 or so (2.5L) it would mostlikely have a coil pack.
  4. 88K5Jimmy
    Jan 10, 2001
    1,323
    Tulsa OK
    Shows you how much I know about 4-cylinders /forums/images/graemlins/histerical.gif
    Thanks guys
