2003 Diesel Speedometer Pegged ???
Discussion in 'The Garage' started by big jimmy 91, Mar 1, 2005.
  1. big jimmy 91
    big jimmy 91 1/2 ton status
    Feb 21, 2004
    639
    Northwestern Ontario Canada
    Since I can only post here ,here goes...
    My friends 03 diesel 4X4 has a problem with the speedometer
    It will work OK for a while , then it jumps up to 180 K in park , and goes over 200 K while driving down the road
    This happens off and on for no apparent reason , everything else works properly.
    Does anyone out there know what would cause this to happen?
    This is a Chev. diesel , automatic (I don't know what engine:dunno:))
    Any info. would be greatly appreciated :grin:
  2. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    It is an electrical issue. Get it fixed before the warrenty is up
  3. miniwally
    miniwally 1/2 ton status Premium Member
    Aug 11, 2003
    3,069
    206
    Colorado
    Tell your freind to join dieselplace.com and do a qick search there.
    The long and short is that GM is havening a problem with these. It is probably the instrument cluster, they will replace the entire cluster. The kicker is that the dealer may keep the truck for several weeks as they determine that the Speedo. being wrong is a safety issue. The clusters might still be on back order which is why the dealer would have to keep the vehicle. They will give out a loner vehicle.
