2003 Yukon XL 5.3L starting issue
Discussion in 'The Garage' started by thezentree, Jan 30, 2006.
  1. thezentree
    thezentree 3/4 ton status
    Sep 19, 2003
    7,198
    NC
    My dad has an 03 XL that won't start if there's less than 1/4 tank of fuel. It runs fine, and will run itself dry, but if you forget to fill it up past 1/4 tank, it won't start until you add more fuel. Anyone know what's going on here?
  2. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    are you going by the fuel gague to determine the level of the tank or by how much it takes to fill the tank up?
  3. 86chevybanshee
    86chevybanshee 1/2 ton status
    May 15, 2004
    917
    beverly MA
    replace the fuel level sensor
  4. thezentree
    Sep 19, 2003
    7,198
    NC
    Going by fuel gauge. Does the fuel level sensor tell the fuel pump whether or not to run? I can't remember whether or not the fuel pump is trying to run when we turn the key to ON but don't try to turn it over.
    Thanks for the help guys.
  5. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    yeah. second that fuel sender issue. gm is recalling the 00-01 models for this problem. may extend it to cover later models, so hold on to your receipts.
