2004 locker question
Discussion in 'The Garage' started by clarkjw24, Mar 7, 2005.
  1. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    What do I need to lock the rear and limited slip in the front of an 2004 Silverado. It looks like the rear is a 10bolt. Are they still 30 spline. What's the deal and the difficulty of installing one in the front of an IFS truck? This is for a friend. He was really upset when I sat him down and explained to him that he didn't have a 4wd truck just one wheel in the front and rear.
  2. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    Does he really need a locker in his '04 truck?
    I believe the rear 10-bolt still uses the same 30-spline stuff that has been around for years but you will probably want to double-check. I also don't believe there is anything available for the front axle.......at least there didn't use to be any locker or anything available.
  3. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,992
    130
    You might be surprised, I know they make aussie lockers for a bunch of IFS stuff, and I bet there are many others who support IFS as well (IFS is getting so abundant, the market is catching up).
  4. clarkjw24
    Dec 4, 2003
    3,531
    McBee, SC 29101
    No he doesn't "need" a 4 wheel drive truck but I'm getting tired of pulling him out every weekend. Sad part is he mostly getting stuck in dead sand.
  5. dyeager535
    26,977
    Definitely check the 10 bolt stuff...the housing has been changed. It may be purely cosmetic, but typically those type of changes indicate *something* internally has been changed.
  6. clarkjw24
    Dec 4, 2003
    3,531
    McBee, SC 29101
    anybody know anything else about this? I can't believe that no one on here has locked an IFS truck.
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Nothing has changed internally. A 10 bolt is still 30 spline and still uses the same parts, minus a few bearings here and there.
    I'm not familiar with what is available for a 1/2 ton front IFS as far as traction devices. I don't think there is anything for it. The bigger IFS has an ARB available. The 8.25 *might*.
  8. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    Nothing is available for the 1/2 ton GM IFS.
  9. skelly1
    skelly1 1/2 ton status
    Sep 2, 2002
    554
    San Diego, CA
    So, I could get an ARB for the IFS on the YukonXL maybe? It's a 3/4 ton. Also, that fricking rear limited slip that's in it does nothing. Lastly, I would like to quote Spicoli. "My dad's a television repairman, he's got an awesome set of tools, I can fix it." That was after he wrecked Jefferson's Camaro and he was talking to his little brother, who, Rat say's "is a good looking kid.".
  10. dyeager535
    26,977
    As far as I know GM is still using the gov-lock. It's funny, go check out eaton's web site, they now call the gov-lock "G80" (GM's RPO code for traction aiding rear diff) there. :)
    If he's already broken it, definitely going to want to get something different.
  11. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Lock rite makes No Slip lockers for the 10 and 14 bolt front axle on IFS trucks. Problem tho I think is after 2000 GM went to a full time 4x4 system on many trucks Cant use a locker on the front if you have full time 4x4. So unless you have locking hubs or the old style IFS axle disconnect. You should not run a locker in the front.
