2004 suburban
Discussion in 'The Garage' started by surpip, Oct 24, 2005.
  1. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    how to reset the check engine light?
    after oil change
  2. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    you mean the change oil light right?
    check engine light has nothing to do with oil.
    just turn the key on (engine off) and press the gas pedal to the floor three times to resest the change oil light.
    ryan
  3. djsblaze
    djsblaze 1/2 ton status
    Jul 7, 2003
    318
    Oklahoma
    I have a 2003 3/4 ton Sub. Turn key to on position, fully depress gas pedal three times, should reset itself (assuming you have all the electronic gizmos that mine does). Hope it works...
  4. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    oops. i forgot.
    if you have all of the buttons on the steering wheel, press the button that looks like a gas pump untill you see the oil life come up on the driver information center. then press and hold the return button untill it resets.
    ryan
  5. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    nope not a fancy one, Its a work truck
    GOV
    thanks for the quick reply
