2006 Build up
Discussion in 'The Garage' started by ryanstrucking, Mar 14, 2006.
  1. ryanstrucking
    ryanstrucking 1/2 ton status GMOTM Winner
    Feb 2, 2003
    182
    Calgary AB Canada
    We'll seems I just can't leave good enough alone lol.
    The Blazer worked better than expected last year but, time to drop some more $$$$ in the K5.
    Started by tearing the front 60 apart to replace the worn ARB o-rings only to find I had a chipped ring gear :mad:. So, ordered new gear set and while I was at it decided to upgrade the rest of the front, including Yukon axles inner/ outer (35 spline) and a new set of drive flanges from NWF. With that done I also added a set of 300M U-joints from Bobby longfield.
    Then I moved on to the motor.The 350 has been a great motor but not enough snort, ssssoooo I just finished swapping in a Injected (TBI) 454.
    Then came the tranny, the built 700R4 is getting a new valve body from TCI (reverse manual with compression breaking). The 203/205 are getting new seals/ bearing. as for the rest of the blazer, gutted the dash in favor of some newer gauges (auto temp) to better montor the motor and air. I also removed the power doors in favor of a set of manual that will be pinned for easy removal. A pair of tube doors are also in the works to go along with a 6 point cage in the next month.
    Here are a couple shots of how it is lookin as well as some of the parts being added.
    I will try to post up on the progress as it happens.
  2. ryanstrucking
    Feb 2, 2003
    182
    Calgary AB Canada
    Heres a pic of my axles and drive flanges
    The Tranny/ t-cases before the over haul
    and the front 60 on it's way to get the gears installed
  3. stockk5
    Apr 13, 2004
    2,033
    71
    Cromwell, CT
    well i went to change my gear oil annnd...got a new motor... haha nice work man.
  4. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    Looks good. Are you going from a TBI 350 to TBI 454? If so, it should just be a few connector changes and a PROM change for the injection system to work....right?
  5. jaysonsk5
    jaysonsk5 1/2 ton status
    Aug 11, 2005
    229
    eastern iowa
    what axle shafts are them? and where is the pic of the longfeilds? i'm planning on ordering a set of them in the next few days, so could you post up your thoughts on them when you get them-thanx-jayson
  6. ryanstrucking
    Feb 2, 2003
    182
    Calgary AB Canada
    Looks good? What truck are you looking at :haha:.
    Should be pretty nice when it's done though (I hope)
    Yes I'm going from a TBI 350 too a 454 TBI.
    That part of the swap is done.........
    But I'm still trying to find the right headers for my truck (shortys)
    Anyone know were I could get a set from? maybe a part #
  7. jays68yak
    jays68yak 1/2 ton status
    Feb 27, 2003
    973
    Gilroy, CA
    Summit racing part number HED-68610 chevelle shortys. Thats what Im running on my 454 in my 79 blazer frame.
  8. ryanstrucking
    Feb 2, 2003
    182
    Calgary AB Canada
    Thanks for the reply Jay, How do they fit for you?
  9. jays68yak
    Feb 27, 2003
    973
    Gilroy, CA
    Id show you pics but my site is down and my stupid hosting co is not responding to my emails. :mad: They are about to loose a customer.
  10. ryanstrucking
    Feb 2, 2003
    182
    Calgary AB Canada
    List keeps growing
    Adding full Hydro with PSC ram and orbital. To finish off the sttering I ordered a pair of arms from NWF (those guys are awsome to deal wit, highly recomended). Heres a couple more shots of my 300-m u-joints and the steering parts (minus the clevis ends as they were back ordered).
  11. tiger9297
    tiger9297 1/2 ton status
    Jul 23, 2004
    1,205
    Tupelo, Mississippi
    specs on 454? hp, tq, which TBI are you running?
  12. mouse
    Nov 10, 2003
    1,448
    Great Falls Mt
  13. y5mgisi
    y5mgisi 1 ton status
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    I just got a hard on...
  14. ryanstrucking
    Feb 2, 2003
    182
    Calgary AB Canada
    Heres another pic for you JAson. The axle shafts are Yukons and heres a pic of the 300-m's. went togrther very nice, hope they hold up...
  15. ryanstrucking
    Feb 2, 2003
    182
    Calgary AB Canada
    Don't know the specs on the 454. It's a stock 454 out of a 88 chevy 1 ton.
    And I'm running the factory TBI set-up that came with the truck.
    I'll have to do a bit of diggen to see what the stock spec are on the motor.
    Don't have any plans for the motor this year other than a set of headers.
  16. ryanstrucking
    Feb 2, 2003
    182
    Calgary AB Canada
    Hey Steve _Kibbe
    Here is a picture of my rear spacers....
    they are made out of a solid piece of 4140 HTS.
    They look scary, but I'm not to worried about them as my rig is no high flying truck..... To heavy for that :haha:
  17. jaysonsk5
    Aug 11, 2005
    229
    eastern iowa
    thanx ryan, that is the same set up i'm going to run. do you have any pics of them put together? did you have to grind on the yoke any like with the ox ones?
  18. 468k5
    468k5 1/2 ton status
    Jul 28, 2004
    142
    SE Mn.
    damn Ryan I'm starting to feel bad, mines gonna almost be a carbon copy.
    AHHHHHHH who am I kidding mine will turn out like ****! lol
    sweet rig man!!
  19. ryanstrucking
    Feb 2, 2003
    182
    Calgary AB Canada
    Hey Jay.
    I didn't have to do any grinding on my axles to instal the yokes.
    Everything fit together like a glove :D
    Very happy with everything so far...Just have to wait and see how they hold up to the power and tires......
  20. ryanstrucking
    Feb 2, 2003
    182
    Calgary AB Canada
    Hey.
    Glad to see I'm not the only guy out there with the ideas I have, and thanks for the complement.....
