203 4x2 conversion kit
Discussion in 'The Garage' started by Smitty, Dec 31, 2003.
  1. Smitty
    Smitty 1/2 ton status
    Sep 1, 2000
    999
    Crestview, FL
    Is there a simple way to tell if a 4x2 kit has been installed in 203 without tearing it apart for a look?
  2. dhdescender
    dhdescender 1/2 ton status
    Aug 10, 2002
    628
    Qualicum Beach, British Columbia, Canada - Eh.
    If the shift pattern differs from the standard NP203 pattern.
  3. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Put the 203 in the 2wd position, have some drive the rig while you watch to see if the front shaft spins.
  4. Smitty
    Sep 1, 2000
    999
    Crestview, FL
    I don't have the engine in the truck yet. I take it from this post that I should be able to put it in 2wd and if it has the kit in the transfer case I will be able to turn the front output shaft by hand? I'm assuming that the fulltime aspect of the transfer case would keep the front shaft from turning by hand unless it has been converted.
  5. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    /forums/images/graemlins/thumb.gif
