203 adapter to TH350 mounting bolts.
Discussion in 'The Garage' started by BadDog, Jun 23, 2003.
  1. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Ok, looks like the box-o-bolts that came with my son's K5 did not include all the bolts that go from the adapter to the trans case. They are "special" bolts with an o-ring surface at the head (basically the last thread is missing) and a "washer" built into the head solid (I'm sure there is a name for that, just don't know it).
    Anyway, I have 3, need one more. "Finding" one will be a major PIA I'm sure. Anyone ever try to use a regular bolt with an o-ring? I suspect it will leak. What about regular bolt and RTV on the threads? With an o-ring? Not something I'm terribly inclined to "just try it" since it requires tearing the doubler back off the tranny if it leaks. For those that don't know, it would leak gear oil onto the outside of the trans case, not inside... I just hate leaks...
  2. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Just a grade 5 bolt, with "The right stuff" will work fine.
    "The Right Stuff" is the cat's Meow. better than the blue rtv stuff. No leak's. /forums/images/graemlins/grin.gif
    Better yet, since the "O-ring's" have a tendancy to roll up and twist anyhow, is to "Right Stuff" all the bolt's, and toss the o-ring's. /forums/images/graemlins/grin.gif
  3. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I finally scrounged a bolt that is 1/4" longer and has a 1/4" shank that will work fine for an o-ring. I also found out that one of the trans case holes had the first 1/4" or more of the threads stripped out. /forums/images/graemlins/frown.gif So, the longer bolt will be good there after running the threads on down with a tap.
    Also, I usually use the Ultra Black, never used "the Right Stuff" before, though I've heard it mentioned a few times...
  4. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Whatever you wind up doing, don't forget the locktite on the threads, ask Marv about that.....
  5. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Hehe, yeah. If it's a structural bolt and I can't get to it once assembled, all that stuff gets red "high strength" loctite. If it's outside, blue or red depending...
  6. mosesburb
    mosesburb For Rent Premium Member GMOTM Winner
    Apr 20, 2003
    2,175
    132
    Phoenix AZ
    I only use the ultra black myself. That stuff works great and I have never had a leak yet. It is extremely similar to the Right Stuff, just not in the aerosol can.
  7. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    I've done this many-a-time /forums/images/graemlins/deal.gif....
    Marv
