203 and 205 T case help
Discussion in 'The Garage' started by RampageFSJ, Sep 12, 2005.
  1. RampageFSJ
    RampageFSJ 1/2 ton status
    Aug 18, 2005
    121
    Ulysses KS
    I`m planning right now and I went to Northwestfab.com and found NP 203 32 spline input for 2 prices. One price with a new input seal and bearing and the other without one. I have a 27 spline 203 lying around and am planning for a doubler anyways so I may swap that in before a 205 swap. I was wondering if the 27 spline input seal and bearing is in good shape, can I use that with the 32 spline input? And I`ve heard everywhere that a 205 needs machining work to fit a 32 spline input in due to a larger bearing. How much needs done and do I just take it to a local machine shop and tell them what to do? How much does that usually cost?
  2. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    The 32 spline is the "big bore" case, your 27 spline seal etc. won't work with a 32 spline input. Take it to a machine shop and tell them you need it bored out to however big the 32 spline input is (I don't know) the machining fee shouldn't be outrageous, it's not a real big job.
  3. spoolnaround
    spoolnaround 1/2 ton status
    Apr 8, 2002
    1,419
    Kingsburg Ca
    I paid $100 to have my case machined to accept the bigger bearing. Ive heard of peole paying $175.
  4. RampageFSJ
    Aug 18, 2005
    121
    Ulysses KS
    Thanks.
