203 and drives
Discussion in 'The Garage' started by Muddytazz, Dec 21, 2002.
  1. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    I want to take out my front/reardrivelines so i can narrow down vibration origin. My 203 is still full time, so which gear should i put the t-case in if I just drive it with just the front shaft install and which gear for just the rear one installed.
  2. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Either Hi Lock or Low Lock I believe. These are the only two that lock the differential in the 203 together so if you only have 1 shaft hooked up it won't just sit there and spin.
  3. Grim-Reaper
    7,385
    Atlanta
    It's the front. blown joint in the CV. You usualy can see they are bad when they are in the truck. Start there first.
