203 cases: do they have two shift rods ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by R72K5, Jun 12, 2003.
  1. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    on stock 203 cases int he 70s auto trans trucks do they have two shifting rods on the same threaded shaft ?? is that correct ? if not on 203 cases then on what ? this one with two rods is not a 205 i know and its not aluminum housing, its iron with aluminum tailhousing, one had flat flange output and other is U joint output, whats correct and whats not in the 70s blazers ?
    thanks
  2. JustHorsinArownd
    JustHorsinArownd Registered Member
    Mar 20, 2003
    77
    Flagstaff, Az.
    On my 203 in my 76 there are two linkages underneath the floor. One for high and one for low. I've had to adjust both already. hehe Hope this helps you out some.
    Allan
  3. JustHorsinArownd
    Mar 20, 2003
    77
    Flagstaff, Az.
    OH and a U-Joint output.
    Allan
  4. Frank74
    Frank74 Registered Member
    Aug 28, 2002
    36
    Woodland, CA
    There are indeed two shift rods, one selects 4 or 2 wheel drive, and the other selects the speed if I remember correctly. I also adjusted the length of them in order for the shifter to fully engage properly, it also helps prevent the case from popping out of gear.
  5. mud390
    mud390 1/2 ton status
    Oct 31, 2002
    1,210
    Little Rock, Arkansas
    I just had a crazy thought? Could you twin stick a 203? Would it even be worth the time since its a full time case? Any ideas or thoughts?
    Kris
  6. blasterD
    blasterD 1/2 ton status
    May 24, 2003
    410
    Anchorage Alaska
    Twin stick should work if you had a part time kit in there. If not one lever would be high-lo and the other would be lock-unlock
  7. mud390
    Oct 31, 2002
    1,210
    What about just manual hubs on the axle? Or would it only work with the part time kit that goes in the transfer case?
    Kris
  8. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    2 wheel drive ? huh ? these are 203 cases..
    one more Q about these cases, one has speedo on opposite side of the output shaft housing
    and also one case has evenly tapered down output sleeve/shaft, and the other case has bottlenecked down output sleeve/shaft
    do these both sound like GM 203 cases ?
    thanks all /forums/images/graemlins/laugh.gif
  9. blasterD
    May 24, 2003
    410
    Anchorage Alaska
    If you just put manual hubs on and didn't change to a part-time kit you would have to put it in 4lock to get it to move. The differential in the 203 acts just like an open rear diff until you put the part time kit in. Unlocking the front hubs would be like lifting a rear tire with an open diff.
  10. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    Kris
    the stock 203 trucks with manual hubs swapped onto them can only be unlocked at the hubs, the axle shafts and front driveshaft would still remain under power at all times, especially in one of the two loc ranges
  11. mud390
    Oct 31, 2002
    1,210
    Thats what I figured, but I can always hope. Maybe one day I'll swap it out in favor of something better. Thanks again!
    Kris
  12. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    The np203 is a great cast iron case and with a part time kit becomes quite usefull. It converts is to 4wd-high-lock,2wd-high, Nuetral, 2wd-Low, 4wd-Low-Lock. This is especially usefull if your running a locker up front since you can shift on the fly between 2wd-Low and 4wd-Lock and restore a full turning radius but unloading the front locker. Having a lot of flex, a rear locker and good traction, I only use 4-lock for the hardest obstacles and generally run around in 2wd in most the places everyone else is running 4wd. The last little bonus to the np203 is the 3:1 reduction that can be swapped in now in place of the 2:1. The chain design is just as strong as the gear design of the 205, most fail due to poor maintenance or absolute abuse. The biggest drawback to the np205 is the 1.96:1 gear ratio.
    And ORD has a guide to identifying them here:
    http://www.offroaddesign.com/Transfer%20Case%20ID%20Guide.htm
  13. jekbrown
    May 19, 2001
    45,032
    369
    Vancouver, WA, USA
    chains... as strong as gears... wha?!
    j
  14. Frank74
    Aug 28, 2002
    36
    Woodland, CA
    My bad, forgot to mention mine has the part time kit on it.
  15. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    hehehe /forums/images/graemlins/laugh.gif :P /forums/images/graemlins/rotfl.gif
  16. Okiemuddog
    Okiemuddog 1/2 ton status
    Mar 3, 2003
    1,260
    Guthrie, Oklahoma
    You can indeed twin stick a 203, but you won't have the range selction for front and rear like a 205 twin stick does. Mine is a twin stick, it eases shifting quite a bit, if you are running a p/t case then one stick is 2wd and 4wd, the other stick is high, neutral, and low range. I just thought I would throw my 2cents in. /forums/images/graemlins/thumb.gif
    Krennen
  17. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Kris
    When you twin stick the 203:
    If it's not converted:
    1- Loc/ unloc
    2- High/neutral/ Low
    If it is converted:
    1- 4wd/2wd
