203 center cap removal ???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by swilson, May 15, 2003.
  1. swilson
    swilson Registered Member
    Mar 6, 2003
    18
    Amarillo TEXAS
    I have a '74 with a NP203. Whats the best way to get the hub center caps off without totally destroying them??? I know they are supposed to pry off, but I think the p.o. must have driven them on with a 16lb sledge or something. Can't get anything to catch on the edges to pry or even catch with a rigged puller. Help!
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    I just use a big screwdriver and twist the screwdriver instead of prying /forums/images/graemlins/thumb.gif
  3. swilson
    Mar 6, 2003
    18
    Amarillo TEXAS
    Tried that first and didn't get anywhere. These things are really stuck on there. I'm almost to the point of drilling holes in them so I can wedge a prybar in and pull them out. HELP! /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif
  4. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Have you tried a hammer and a BRASS drift/punch...brass will not damage it.
  5. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    we had to drill holes and pry out my friends drivers side one, u gotta do whatcha gotta do. /forums/images/graemlins/thumb.gif
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/truck.gif
  6. Kyle89K5
    Kyle89K5 1/2 ton status
    2,273
    OKLAHOMA
    Is it the external flange with the bolts? If it is, then you aren't going to hurt those center covers. I used a pretty good sized prybar to pop mine off. The P.O. has used a LOT of silicone on them. They are beefy enough, just pry on em...
    KP
  7. swilson
    Mar 6, 2003
    18
    Amarillo TEXAS
    Nothing visible on that hub except the chrome center piece. (Sorry no pics...no camera...yet /forums/images/graemlins/rolleyes.gif) I assume (hope) the bolts are under the cap. Can't even hardly use a punch and hammer due to the angle needed to get behind the lip of the cap. Maybe I'll just cut them out with the Dremel tool /forums/images/graemlins/angryfire.gif. Any last ideas?????
  8. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    Snap-on makes a cap removal tool and its acutally kinda cheap...like $20 or something like that. I use a long cro-bar when I take mine out for highway travel. I take the flat end and wedge it in between the hub and the cap. Then use the rim/tire to pry on. Do one side then the other and it falls right off.
  9. swilson
    Mar 6, 2003
    18
    Amarillo TEXAS
    Thanks...I'll see if I can make that happen before I hafta get drastic on it /forums/images/graemlins/eek.gif
  10. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    i thought late 77 up were with chrome caps and not before ?
  11. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    My 75 burb has the chrome caps /forums/images/graemlins/thumb.gif
  12. 76SILVERADO
    76SILVERADO Registered Member
    Mar 1, 2003
    52
    AZ
    take the wheel off to get better angle? i had to hit mine all around with a hammer to break it loose. then screw driver method.
  13. swilson
    Mar 6, 2003
    18
    Amarillo TEXAS
    Well Duh!!! /forums/images/graemlins/blush.gif I'm an idiot. /forums/images/graemlins/rolleyes.gif Sometimes the easiest way is not seen because of the hair brained ideas getting in the way. Thanks...will try it when it gets light outside.
