203 converted part time?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by big83chevy4x4, Dec 9, 2002.
  1. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    Awile back my dad bought a 78 blazer for $76 (lucky him) /forums/images/graemlins/shocked.gif. it has a 350/203 with lockout hubs. my question is how do you tell if it has the conversion kit, how does it work, and what is the shift pattern?
    TJ /forums/images/graemlins/truck.gif
  2. Redfrog
    Redfrog 1/2 ton status
    May 4, 2001
    753
    IL
    if you do a search you will find everything you are looking for /forums/images/graemlins/thumb.gif
  3. CooknwithGas
    CooknwithGas 1/2 ton status
    Nov 27, 2001
    332
    Istanbul, Turkey
    Actually I just went through my NP203, so I can help you. If you pull the shifter all the way back, then up one notch, you will be able to check the part time installation.
    Just leave the truck in park with the e-brake set and crawl up under it. You should be able to turn the front driveshaft with your hand if the part time kit is installed and working properly. Remember, the hubs must be un-locked and the shift lever must be one notch forward from the back-position.
    Good-luck with the truck. For $76, I'm sure there's a lot of work to do.
    _____________
  4. pismorat
    pismorat 1/2 ton status
    Oct 29, 2002
    540
    California
    Shift pattern:
    4-low
    2-low
    nuetral
    2-high
    4-high
    I have a 203 with part time kit and hubs and i love it, low range is killer. /forums/images/graemlins/truck.gif
  5. 76_Cheyenne
    76_Cheyenne 1/2 ton status
    Jan 23, 2002
    285
    Missoula, Montana
    To find out, just unlock your hubs, and see if you can drive in 4 hi. If you are full time, your frint driveshaft will just spin and make noises and you wont move. With your hubs unlocked you'll only be able to drive with it in 4loc, or 4low loc. If you are converted, your front driveshaft will never turn unless it is in 4loc.
