203 cross member differ from 205 cross member
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by down4thakrown, Jun 15, 2004.
  1. down4thakrown
    down4thakrown 1/2 ton status Premium Member GMOTM Winner
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    what it says^ /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/thinking.gif
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    nope, even the flat 208 cross member is the same.
  3. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    I'm not so sure. I have 2 '73 K5's, one I used for parts for my project, the other one....anyhow, in tearing down both trucks the crossmembers were different.
    One was TH350/NP203 and other SM465/NP205. The memebers were in the same location fore-aft, but the mounting holes on them were drastically different. The NP205 version also has a side bracket that bolts to the frame rail and helps control torque under power
  4. realsquash
    realsquash 1/2 ton status
    Jul 12, 2000
    778
    SE WI
    I think there were a few different ones but it should be easy to find one to fit. I've never had a truck older than the 76 I have now and it's using a crossmemeber from an sm465/np205 combo on a th350/np205 now. All the other crossmembers I have laying around have the same holes. I've never seen one with the NP205 brace but I've heard of it.
    Andy
  5. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    Yes..they'e different...
    they are almost alike...
    The 205 is closer to the crossmember...
    so the area by the front output is more countersunk..
    then the 203...to make room for the driveshaft flange..
    You can use a 205 crossmember on a 203...
    But the 203 crossmember will hit the front shaft...when running a 205...
    With the th350/205 combo...
    80' is the most common..
  6. down4thakrown
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    what about a 208 cross member?
    would i be able to use that? /forums/images/graemlins/confused.gif
  7. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    No...the 208 is different..
    You could probably modify the 203 crossmember...
    Do you have a torch and a BFH!!!
