203 fulltime transfer case and 205 questions
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BozoWise, May 6, 2002.
  1. BozoWise
    BozoWise 1/2 ton status
    Mar 28, 2002
    1,224
    Lubbock, TX
    I am putting a dana 60 into my 1979 K5 blazer which has a 203 fulltime transfer case. With the lock-out hubs on the D60 hubs in the unlocked position will I have to run the transfer case in high loc? Should I just run the hubs locked and use the transfer case in high. I am going to get a partime conversion for the 203 any suggestions for the kit?
    Thanks for the info.
  2. Grim-Reaper
    7,385
    Atlanta
    If you already have a 205 or can get one for $100 then that's the way to go. It is a better case to use if your not planning on running full time. The part time kit runs about $80.
    For now, as long as the front axle is open, I think the better option would be lock the hubs and drive it In High just like you normaly do.
  3. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    Yep you will have to run with the hubs locked to move.
    Or with the hubs unlocked and in 4loc.
    If you have a 205 to swap in that would be the way to go.
  4. BozoWise
    Mar 28, 2002
    1,224
    Lubbock, TX
    Thanks guys I think I am also going to keep the 205 setup and look into a doubler. I will just run the 203 with a partime kit for now since I want to save as much as I kind and not have drivelines redone until the doubler.
    What kind of partime kits are you guys using. So far I have heard that the Mile Marker rear replacement shaft is the way to go.
  5. ratpack7
    ratpack7 Guest
    ether way will work. I run mine with the hubs unlocked.
