203 (I think) Not goin into 4 low lock
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JustHorsinArownd, Apr 29, 2003.
  1. JustHorsinArownd
    JustHorsinArownd Registered Member
    Mar 20, 2003
    77
    Flagstaff, Az.
    Went out the other day to get the Blazer dirty, shake up the sodas in the cooler etc. and couldn't get it into low lock. Almost didn't get out of the hole we were down in! Goes into 4 high lock just fine. Is there an adjustment or somethin??
  2. JustHorsinArownd
    Mar 20, 2003
    77
    Flagstaff, Az.
    By the way the Blazer is a '76 if that makes any difference.
  3. Okiemuddog
    Okiemuddog 1/2 ton status
    Mar 3, 2003
    1,260
    Guthrie, Oklahoma
    Yup, if you crawl under your /forums/images/graemlins/k5.gif and look at the bottom of the T-case shifter, you will notice that the linkages are threaded. You can adjust your shifter from there. /forums/images/graemlins/thumb.gif
  4. 4x4Freak
    4x4Freak 1/2 ton status
    Apr 21, 2002
    792
    Lubbock, TX
    Try oiling the shifter. When I got my truck it wouldnt go into LOC at all, but after some WD40 it worked fine until I took it out.
  5. Blackmagic
    Blackmagic Registered Member
    Mar 15, 2003
    28
    Fairbanks, Alaska USA
    Mine slips out of loc position. is there something that I can adjust to better that problem?
    /forums/images/graemlins/k5.gifDominic
  6. 4x4Freak
    Apr 21, 2002
    792
    Lubbock, TX
    You might be able to adjust the linkage a little bit. Do a search and I'm sure you will find out how to do it. Also make sure that the shifter isnt hitting the floor. It shouldn't be, but you never know.
