203 kit?
Discussion in 'The Garage' started by 78burb, Mar 23, 2006.
  1. 78burb
    78burb Registered Member
    Nov 6, 2003
    9
    I have the milemarker kit in my 203 and it burnt up the thrust bearing! I was wondering if anyone could tell me if this is a local Napa item or do I have to order the 701 bearing kit from milemarker? It seems like a normal part and it sure would be easier to buy local. Any help would be great. Thanks
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Try your local tranny shop versus napa.
  3. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    How did you find the thrust bearing shot?
  4. 78burb
    Nov 6, 2003
    9
    First off the t-case wouldn't go into 4hi anymore. So I tore into it to find that the bearing was toast. Actually in about 10 pieces in the bottom of the case. When the bearing went it let things have a little play and the part with the teeth that engages 4x4 had the teeth sheered off :eek1: ! Everything else is fine inside I just need the new bearing. I was just hoping to get it local. If I had one to compare with I could take it in to match it up. But mine is long gone. Thanks for the replies.
    Hey Mouse hows things down in Great Falls? I am up here in Whitefish. People from MT showing up everywhere.
  5. mouse
    Nov 10, 2003
    1,448
    Great Falls Mt
    Things are going fine here. Once work slows down the local club will try some wheeling. The mountains still have a lot of snow though. Its always fun trying to see how far you can get (as long as you carry recovery gear).
