203 or 205?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ScoobyDann, Mar 29, 2001.
  1. ScoobyDann
    ScoobyDann 1/2 ton status
    Mar 9, 2001
    305
    El Paso, TX (Far West Texas near Las Cruses
    i now you get this question all the time, but i found a transfer case for $20, it has no tags and its cast iron and still has an adapter on it. Can anyone tell me some definate signs to tell weather it is a 205 or 203 and how can you tell if it cam off a ford, chevy or dodge please help
    check out http//:www.jimjim.coloradok5.com
  2. slider79blazer
    slider79blazer 1/2 ton status
    Mar 23, 2001
    164
    littleton,co.
    usually a 203 is full time 4 wheel drive. if you turn the rear
    yoke the front should turn also. Unless there is a part time
    kit in it.I don't know much about them yet but mine is a 203
    and it's cast iron.
  3. Goose
    Goose 1/2 ton status
    1,127
    South Central Kansas
    Turn the input shaft and see what turns. If both output shafts turn it could be a 203, or a 205 with cold gear oil. Hold onto one of the outputs and see if there is a solid connection. Try to visualize what would be turning when and run through the gear selector. How do you know it's a 203 or 205? There are other cast iron cases that were used by early GMs.
  4. prjt_blzr
    prjt_blzr 1/2 ton status
    Mar 4, 2001
    352
    COS, CO
    The 203 has a double aluminium tail housing. The rear output for the 203 has a large aluminium section for the differential. The 205 does not have this. The 205 is lighter and smaller than the 203. If I remember correctly the 205 weighs about 100lbs. The 203 is in the 130lb range. If you want to do some work to verify the case, remove the side cover from the case. you will either see a chain (203) or just gears (205). The other check is to remove the rear yoke and housing to see if there is a differential behind it if you are not familiar with the cases.
  5. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    The 205 is much shorter, all cast iron, and has a PTO mount (I don't think the 203 has that but not sure). Look around in some of the articles here and at ORC and I'll bet you can find pictures of the 205. Hmm, ORD has a pic of one behind a 203 gear box (t-case minus aluminum housing) in their doubler pictures...
    <A target="_blank" HREF=http://www.offroaddesign.com/catalog/doubler.htm>http://www.offroaddesign.com/catalog/doubler.htm</A>
    The 205 is on the right, the front half of a 203 is on the left.
    Bad Dog
    85 K30 CUCV, 350 TBI, TH400, NP205, D60/C14, 4.56
    Coming soon: 4" lift, 40" tires, massive cutting, shorter wb and rear overhang.
  6. Emmettology 101
    May 9, 2000
    8,126
    FL
    The 203 looks like two t-case bolted to gether. It has a range box and the gear box. The 205 is one box.
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; <A target="_blank" HREF=http://emmett.coloradok5.com>http://emmett.coloradok5.com</A>
    "Pimpin aint easy!"
