203 or 205?
Discussion in 'OffRoad Design' started by ScoobyDann, Mar 29, 2001.
  1. ScoobyDann
    ScoobyDann 1/2 ton status
    Mar 9, 2001
    305
    El Paso, TX (Far West Texas near Las Cruses
    i now you get this question all the time, but i found a transfer case for $20, it has no tags and its cast iron and still has an adapter on it. Can anyone tell me some definate signs to tell weather it is a 205 or 203 and how can you tell if it cam off a ford, chevy or dodge please help
    check out http//:www.jimjim.coloradok5.com
  2. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Turns out I don't have any good pics of a complete 203 or 205.
    205 is a one piece case, it has bolt on bearing retainers, but that's it. It's about 12.5" long
    203 has 3 or 4 different sections and is about 22" long
    Ford is Left hand drop, GM and Dodge are right hand drop for the front output.
    Anyone else want to throw in some pertinent info here?
    Making the world better, one truck at a time.
    SW-ORD
  3. BMRCCR
    BMRCCR Registered Member
    Mar 7, 2001
    33
    Spline counts are different for different versions. You could mess with the shifter and rotate it around a few times to see if it has 2wd or not (only the 205 has 2wd, the 203 if full time 4wd). Just my opinion.
  4. BMRCCR
    Mar 7, 2001
    33
    Nevermind that. Many random 203 cases have been converted by thier owners. The length is the most obvious way to tell.
  5. Emmettology 101
    May 9, 2000
    8,126
    FL
    The 203 looks like 2 t-cases bolted to gether where the 205 is only one case.
    The 203 has a range box and a chain box, hence the 2 cases..
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; <A target="_blank" HREF=http://emmett.coloradok5.com>http://emmett.coloradok5.com</A>
    " Ah.. Hong Kong, home of shiny green suit!"
  6. 84K5WITHAJUNK305
    84K5WITHAJUNK305 Registered Member
    Feb 25, 2001
    41
    Denison TX
    The easiest way to tell is to look at the shifter and shifter boot, assuming there is one. If it's a five position shifter, then it's a 203, if it's only got 4 positions then it's a 205.
  7. prjt_blzr
    prjt_blzr 1/2 ton status
    Mar 4, 2001
    352
    COS, CO
    Look at the shift rails. If memory serves me corrctly. If it has two 3/4" rods going into the front of the case it is a 205. If it has two levers connected to rails going into the side of the case it is a 203.
  8. chrishoz
    chrishoz Registered Member
    Apr 16, 2001
    7
    the 203 has large aluminum planetary gear housing on the tailend 8 in. or so in dia.
