203 part time kit or not???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ol_grayfeather, Apr 2, 2002.
  1. ol_grayfeather
    ol_grayfeather Registered Member
    Jan 15, 2001
    68
    Around Spokane, Washington
    I have a 75 3/4 ton that has a 203 and was wondering what it would hurt if I just put a set of hubs in and then run it in lock, instead of putting in a part time kit?? I read somewhere that when one installs a part time kit that you need to run it with the hubs turned in, for 20 miles or so a month, to make sure the front of the tranfer case gets lubricated. So other than the unnecessary "wear and tear" from rotating the front driveline, whats wrong??
  2. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Nothing, alot of guys just do that, it will helps with gas milage, and you dont have to worry about the front not getting oil.
  3. BozoWise
    BozoWise 1/2 ton status
    Mar 28, 2002
    1,224
    Lubbock, TX
    So are you guys saying that if I switch my front axel to one with warn locking hubs that I can run them unlocked on the 203 even though it will be sending power to the front driveline.
  4. Sparky
    Sparky 1/2 ton status
    Aug 20, 2000
    423
    San Antonio(summer) Texas A and M (school year)
    Yes you can do that, but you dont gain all that much. I would recomend just buying the kit or swaping for a 205 or 208.
  5. just do the kit. it's real easy to install. can easily be done in an hour. get some assembly greese for all the needle bearings and an 1 5/16 socket for the output yoke and you're set. the hubs take about 20 min. good time to check your bearings and seals though while you're in there.
  6. BozoWise
    Mar 28, 2002
    1,224
    Lubbock, TX
    Does the kit add another shifter to the floor? or do you just use only the current one off the 203?
  7. no new shifter. just eliminates the differential inside the case. two differnet kits offered. i used the cheeper one and have had no problems with it at all.
  8. Bigmeats
    Bigmeats 1/2 ton status
    Jul 29, 2000
    523
    Manhattan IL
    One advantage to the part time kit is that you will have a 2 wheel drive low gear now. Just an added benny.
  9. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    i just did the kit, took a little over an hour... i'm doing th ewrite up as i type this...
  10. wheelnut46
    wheelnut46 1/2 ton status
    Nov 27, 2001
    122
    Rhode Island
    Is there a way to tell if the part time kit was done? I have the locking hubs but have no way of knowing anything else. Is there even a simple way to identify what case is in there for sure? I have the L, L Loc, etc. shifter and my front driveshaft spins when I move it by hand. There is no ident tag on this transfer case like on previous trucks
  11. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
    ya Its an 203 .If you can spin the drive shaft it has been done..
  12. Ancient_4X4
    Ancient_4X4 Registered Member
    May 5, 2001
    35
    ND, USA
    "It saves on gas" is a myth. All of the people I've talked to that have put a part time kit in their trucks wish they had never done it. This unnecessary wear and tear talk I hear is a bunch of bs as well.
