203 popping out of low loc
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MTPockets, Apr 23, 2001.
  1. MTPockets
    MTPockets 1/2 ton status
    Feb 19, 2000
    502
    Gainesville, Florida
    started about a year ago. doesnt do it ALL the time, only when i really need it. my co-pilot can put a foot down to hold it when it happens, but it would be nice to fix it for good.
    i have been thinking this is because the linkage needs adjusting or the 1" body lift i have.
    can anyone share their experience with this difficulty.
    thank you in advance.
    MTPockets
    <A target="_blank" HREF=http://coloradok5.com/moneypit.shtml>http://coloradok5.com/moneypit.shtml</A>
  2. join the crowd, man. i use a bungie cord hooked to the bottom of the dash to keep mine in. works good so far.
    78, 350/350/203, 3/4 ton, 4" lift, 35" BFGs[​IMG]
    <A target="_blank" HREF=http://bluebeast.coloradok5.com/>http://bluebeast.coloradok5.com/</A>
  3. slider79blazer
    slider79blazer 1/2 ton status
    Mar 23, 2001
    164
    littleton,co.
    mine did that in the middle of a trail i would hold it as tight as i could but it would still pop out. my lock nut on my linkage backed off so it was floating back and fourth. check that first if thats not it check your tranfer mounts. if thats not it look inside the case you might have some worn out parts.
    whats a 4 letter word for farm wagon? (ford) [​IMG]
  4. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    Mine did that and I got tired of having friends or the wife hold it down. If I was alone then I was SOL, so I dumped the 203 for the 205. Problem solved :)
  5. doonjumper
    doonjumper 1/2 ton status
    Mar 9, 2001
    948
    Visalia, California
    The gear is worn on the edges really bad and there isn't enough meat to hold it in when you throtle into it.Since you have to break the case open you might as-well replace the chain.
  6. slider79blazer
    Mar 23, 2001
    164
    littleton,co.
    my wife pulled that duty to but i have'nt had a problem since i tighten the nuts up.
  7. FastEddy
    FastEddy 1/2 ton status
    Feb 3, 2001
    182
    southeast manitoba, canada
    Mine does the same thing, only worse....my friend first broke the seat back from pushing it in with his foot, then finally the seat broke through the rusty floor....yes, she's pretty rusty, but has 18 inches of lift, 40 inch tires, and headers thru the hood....it's been parked for awhile and i have to resurect it....gonna toss the body and put either a 1/2 ton cab or an s-10 ext cab....also have an 89 astro van here with no motor.....was thinking of using that body, but i would like to keep the weight down.....Ed
  8. Wheels
    Wheels 1/2 ton status
    Aug 18, 2000
    638
    Have you tried adjusting the linkage or checked to see if the linkage is worn out? I'd try adjusting it first and check for excessive play on the linkage at the same time.
