203 Shaft Conversion - Shift Pattern Question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 79Guy, Oct 28, 2000.
  1. 79Guy
    79Guy 1/2 ton status
    Jul 8, 2000
    178
    Southeastern VA
    OK, I understand with the 203 shaft conversion, shift pattern changes, with 4 Hi, 4 LO, 2HI, 2LO.
    What happens to "Loc", as in the "4 Loc" position. Does the "Loc" capability go away, or are "4" always "loc"d.
    '79 Guy
    1 Blazer - 7 Children
    http://79guy.coloradok5.com
  2. Grim-Reaper
    7,385
    Atlanta
    Loc will be your 4x4 modes. High and Low will be your 2x4 modes and yes you get 2 low.
    Diging it in the dirt with my K5's
    Grim-Reaper
    http://grimsk5s.coloradok5.com/
  3. 79Guy
    Jul 8, 2000
    178
    Southeastern VA
    Re: 203 Shaft Conversion - Shift Pattern Question - Updated
    I may not have asked that right.
    I understand before the conversion there is a differential between the driveshafts that let them turn at different speeds. "Loc", locks the front and rear driveshaft so they must turn together (Kind of like a "locker" for the driveshafts).
    My question is, after conversion, in 4HI and 4LO, are the driveshafts "Loc"d or Not. If they are "Loc"d, that makes driving a little bumpy on turns. If they are not, it would seem I have lost some capability that might add more traction.
    '79 Guy
  4. 79Guy
    Jul 8, 2000
    178
    Southeastern VA
  5. Wheels
    Wheels 1/2 ton status
    Aug 18, 2000
    638
    Before the conversion, you have five shift positions, 4 low-loc (locks the two drive shafts together), 4 low (allows a little slipage), N (nothing spins), 4 hi (same as 4 lo only in high range), and 4 hi-loc ( same as 4 low-loc except in high range).
    After the conversion you still have five shift positions, 4 low-loc (same as above), 4 low (low range two wheel drive, front drive shaft does not spin), N (same as above), 4 hi (high range 2 wheel drive, front drive shaft does not spin) and 4 hi-loc (same as above).
    This deals with the 203 part time conversion assuming that you install manual hubs. If you dont install the hubs, then all bets are off. Don't laugh, a friend of mine did this in a Ramcharger and ended up rebuilding everything.
  6. 79Guy
    Jul 8, 2000
    178
    Southeastern VA
    Thanks. That helped alot.
    What you are saying is (I think), The "Loc'd" mode gives you 4WD, (Hi and Lo). The "UnLoc'd" gives you 2wd. The "UnLoc'd 4WD" goes away.
    '79 Guy
  7. Wheels
    Aug 18, 2000
    638
    That's it.
