203 teardown?
Discussion in 'OffRoad Design' started by TONYP, Apr 8, 2003.
  1. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    I just got my 203 range box and adapter to start my Doubler project. I have the alum output off and the center cast part off, now I'm not sure what to keep on the range box out shaft, It sticks out about 8" and has the sprocket for the chain on it. I have my books at home so I can't ref them but want to get this thing apart. anyone... /forums/images/graemlins/ears.gif
  2. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    IIRC, the shaft that Dr. Watson sends you replaces it. I'm having trouble figureing out what bearing to use /forums/images/graemlins/crazy.gif
    i have been too bust tearing apart the 205 and getting it ready to be machined I have forsaken the 203 for a bit. maybe paint it tonight and get it bolted to the adapter tomorrow.
  3. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    That aluminum plate and the shaft comes out, take your time getting the snap rings off, they are a bitch. The new shaft will be installed into the doubler itself with the bearing from the alumium plate on the range box and the snap rings.
  4. TONYP
    Aug 13, 2002
    2,116
    so cal
    the shaft with the alum plate came out when I pulled the cast housing off, and all the needle bearing fell out at the same time (got them all). So i take the snap ring off and take the alum plate off...going to do it right now...
  5. TONYP
    Aug 13, 2002
    2,116
    so cal
    got it apart, now do i need to keep the old roller bearing that were in the range box and around the old shaft, when i pulled the shafe out they fell into the range box, if I need to keep them how many were there...
  6. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    15 fat ones. the skinny ones are junk
  7. TONYP
    Aug 13, 2002
    2,116
    so cal
    got them and put them in a bag...now do you keep the alum disk that was on the old shaft?
    so far i have
    1-range box
    2-loose gear in range box 3"
    3-loose gear in range box 6"
    4-15 3/16 needle bearings
  8. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    do you have pics? i am having a tough time visualizing all this stuff. pics would really help.
  9. TONYP
    Aug 13, 2002
    2,116
    so cal
    ok i have the gear on the fork #3, gear #6, and do i keep the alum plate #9 ,looks like a round disk...
  10. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    i don't think so. but what is the bearing we need? I'll go snap a pic of mine really quick...
  11. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    So you mean this?
    I think the bearing I need is under this, not sure how to get it off...but i havn't been looking at it much, been claening and preping the 205 and 203 range case.
  12. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    Update:
    I re-read my instructions, and when and used a rubber mallet to get the shaft in the above pic out. Then there is a snap ring holding a rear "thingie" on. then slide the shaft out of the aluminum housing.
    Using 3 screw drivers, i got the snap ring out of the aluminum housing, and then the bearing. The aluminum housing isn't reused.
  13. TONYP
    Aug 13, 2002
    2,116
    so cal
    when you take the snap ring (#45) off(took me 1 min)you have the "input shaft bearing" (#42) then the alum plate "input shaft bearing retainer"(#42) then "thrust washer" (#41) then "low speed gear and bushing"(#40)..I let all the roller bearings come out the end of the shaft then worked the shaft out...
  14. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    I hope you guys got this figured out, I think everything is right so far. The caged ball bearing comes out of the alum. dome shaped bearing retainer and goes into our adapter, you keep the 15 needles to re-install, and all the parts under the bearing on the factory shaft come off that shaft and get installed on our shaft.
