203 to 205 swap
Discussion in 'The Garage' started by olskool, Mar 2, 2006.
  1. olskool
    olskool 1/2 ton status
    Oct 19, 2005
    138
    the frozen tundra
    This may be a stupid question, but can I just remove the flange from the front driveshaft on my 203 and make it work on the 205? shorten or lengthen the driveshaft as needed.
  2. olskool
    Oct 19, 2005
    138
    the frozen tundra
  3. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    do you have both t-cases sitting around? shouldn't be hard to try to bolt the flange to the 205 and you'd know for sure if it worked...
    j
  4. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    What transmission are you using? The 4X4 TH350 has a 27 spline short output that works with a 203 and a 205.
  5. olskool
    Oct 19, 2005
    138
    the frozen tundra
    The 205 is a yoke style and the original 203 had a flange. Can I just press the flange off the driveshaft and bolt it to the 205? Or press the flange off and install a different u-joint to bolt up to the 205?
  6. NorthWestFab
    NorthWestFab 1/2 ton status
    Jan 11, 2005
    311
    Canada Eh.
    Shouldn't be a problem as long as they're both 30 spline front outputs, some of the early NP205's were 10 spline front output shafts.
  7. olskool
    Oct 19, 2005
    138
    the frozen tundra
    They are both 1977 transfer cases so would that mean that it would work?
  8. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    I think your 205 would have the 10 spline output.
  9. NorthWestFab
    Jan 11, 2005
    311
    Canada Eh.
    You are right around the changeover years, GM was notorious for carrying old stock over from year to year - your best bet is to pull the yoke off, and if the NP205 flange is 30 spline - your in business.
