203 TO 205 SWAP
Discussion in 'OffRoad Design' started by mtnsun, Nov 29, 2002.
  1. mtnsun
    mtnsun Registered Member
    Oct 3, 2002
    50
    COLORADO
    Just asking a simple question... I want to change out my old np203 for a np205. I will be hooking it up to a T350 Trans. in my 77 GMC Jimmy. I have had several explinations and diffrent examples. I want to find out the right parts so I only do this once the right way.
    Thanks for the help,
    ~JJ /forums/images/graemlins/k5.gif
  2. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    [/ QUOTE ] that dosen't sound like any fun... /forums/images/graemlins/rotfl.gif /forums/images/graemlins/tongue.gif, I think you've gotton about all the info you needed.. The right adapter for the right engine, slightly bigger hole for the stick, having to adjust the cross member and other mounts, and new drivelines... /forums/images/graemlins/thumb.gif
  3. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    You need a TH350 version NP205 complete with adapter housing, drive sleeve, and 27 spline input gear. If you have all this, it'll bolt right up. You will have to change the driveshafts but the crossmember has a real good chance of staying put, if not it won't move much.
    The best way to do this is buy the case with all the right parts together, if you don't, the adapter pieces alone make this a very expensive conversion. It runs about $550 or a bit more to buy it all new.
