203 to 205
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 79blzrfan, Jan 27, 2005.
  1. 79blzrfan
    79blzrfan Registered Member
    Mar 9, 2004
    21
    Michigan
    I have the 203 fulltime case in my 79 K5 how much work is it to go to the 205? Will I need new driveshafts and a will it mount to the turbo 350 trans with out an adapter?
    Scott
  2. ironnut
    ironnut Registered Member
    Jul 14, 2004
    77
    Missoula, MT/Redmond, WA
    I did the swap on my 76'. You need to have the th350-np205 adapter, because the adapter currently on your rig is for a th350-np203. The shifter linkage is also different. It's a realtively easy swap, took me and a buddy a long afternoon. Try to get a tranny jack or something similar to make your life a whole lot easier. I rented one from a rental store. You will need to have your driveshafts modified.
  3. OrangeCrushK10
    OrangeCrushK10 1/2 ton status
    Jan 25, 2003
    1,425
    Square State + Suspension Item
    I did this exact swap on my wife's '79 K5.
    You will need:
    *NP205 Transfer Case
    *NP205/TH350 adapter
    *The coupler sleeve thing that connects the output shaft of the TH350 to the input shaft of the NP205 (I forgot this part and had to run back to the junkyard to get it!)
    *Extend the rear driveshaft 5 1/2" (I think, better measure to make sure)
    *Buy and install a SYE kit for the NP205 (what I did) OR buy a slip yoke for your driveshaft.
    I think that was about it.
  4. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    From what I can remember, only 1980 NP205's are slip yoke
  5. Resurrection_Joe
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Also, figure out how much work and money it is it is to switch, THEN figure out how much work and money it is it is to make a doubler
  6. NorthWestFab
    NorthWestFab 1/2 ton status
    Jan 11, 2005
    311
    Canada Eh.
    1980 and newer NP205's are all slipyoke, excluding those from crewcab trucks, which were fixed.
    1980 was the last year for the NP205 in all trucks except the K30's.
  7. Resurrection_Joe
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Shawn Spickler has betayed me!
    From his driveshaft article -
  8. 79blzrfan
    Mar 9, 2004
    21
    Michigan
    Thanks for the help. I'll look at all the costs and make my decision before I spend the money on the part time kit for the 203.Scott
