203 to 208 conversion
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by monte0172, Jun 30, 2003.
  1. monte0172
    monte0172 1/2 ton status
    Sep 16, 2002
    182
    Memphis, TN
    I have done a search but didnt come up with anything. I was wondering has anyone done a conversion like this? I was looking at this from merely a gear ratio stand point. Being a 203 has a 2.01:1 Low Range and the 208 has a 2.61:1 Low Range. If there is a post already here or someone has some knowledge in this area anything would be appreciated. Thanks,
  2. monte0172
    Sep 16, 2002
    182
    Memphis, TN
  3. K5Dan
    K5Dan 1/2 ton status
    Nov 15, 2002
    583
    Port St. Lucie,Fl
    i think you'll need a different adapter.drive shaft lenths may be different. the 208's a slip yoke in the rear. that's all i can think of. i'm sure someone else will know more on this .and i'm sure it's been done more than once! /forums/images/graemlins/thumb.gif
  4. monte0172
    Sep 16, 2002
    182
    Memphis, TN
    I cant believe that no one has ever done this conversion. Im just looking for some tips and helpful hints if anyone has any. thanks,
  5. K5Dan
    Nov 15, 2002
    583
    Port St. Lucie,Fl
  6. K5Dan
    Nov 15, 2002
    583
    Port St. Lucie,Fl
  7. monte0172
    Sep 16, 2002
    182
    Memphis, TN
    Thanks you very much!!! It looks like all Ill have to do is put a slip yoke on the drive shaft and a 200$ adapter to the transmission and im in buisness. Looks like ill just find a 205 and make a doubler since i just had my 203 rebuilt. Thanks for all the help k5dan. I appreciate it.
  8. K5Dan
    Nov 15, 2002
    583
    Port St. Lucie,Fl
    anytime! /forums/images/graemlins/grin.gif /forums/images/graemlins/thumb.gif
  9. COCHEV
    COCHEV 1/2 ton status
    Jul 9, 2002
    4,055
    Washougal WA
    the output shafts are different lengths on th350s that had 203s/205s vs the ones that had 208s. 208 version th350s had much longer output shafts. i did this swap by swapping the output shafts and useing the 208 adaptor.
  10. monte0172
    Sep 16, 2002
    182
    Memphis, TN
    Its sounds pretty feasible. I was also thinking of just having the transmission rebuilt that the 208 is bolted to and puttin it in my blazer all i know about it is that 3rd gear has died I havent even bothered to look and see what model it is yet. The truck also has a dana 44 front but the genious i got it from welded the spider gears together and broke one of the axles and yokes. so its pretty much trash. While i have my transmission and transfer case out i was looking into other cheap options of making it better but it looks like what i got will do fine for now thanks alot guys i really appreciate it.
