203 To A 205
Discussion in 'The Garage' started by will_b_shady, Aug 28, 2006.
  1. will_b_shady
    will_b_shady Registered Member
    Aug 8, 2006
    11
    mohave valley, az
    I Want To Go From The 203 To A 205 In My 76 K5. Will It Bolt Right Up Or What Else Do I Need To Make The Change Other Than Hubs?
  2. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    you will need the corect adapter and the corect 205 for your transmission type. also you will probley have to change the length of your drive shafts
  3. spoolnaround
    spoolnaround 1/2 ton status
    Apr 8, 2002
    1,419
    Kingsburg Ca
    Hubs?? If you have the adapter for your trans and the 205 all need is the right shifter and to shorten your front drive shaft and lengthen your rear and you should be good to go. Been there done that. Cant think of anything else at the moment you need.
  4. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I say spend the money now for the double adapter and bolt the 205 to the back of that. You have to change drivelines either way might as well get 4:1 while your at it:D .
    Ira
