203 tranfer case speedometer cable
Discussion in 'The Garage' started by barneybasher1010, Nov 9, 2005.
  1. barneybasher1010
    barneybasher1010 1/2 ton status
    Sep 25, 2005
    908
    PORTERVILLE CA
    what is the "thing" that is on the 203 transfer case called where the speedometer cable is connected? The "thing" is in between the speedometer cable and the t case. The speedometer cable screws onto this not the t case itself.
  2. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    it might be a ratio adapter, might have been used when there were no speedo gear combos for the axle ratio
  3. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Seem to remember they have a gearbox before the cable......mine also has a VSS unit on my '78 for the TBI motor.
  4. dyeager535
    26,979
    Are you talking about the piece that is held into the t-case or a piece that threads onto the t-case?
    If it is held in, that's a speedometer gear sleeve if I remember my GM lingo correctly, but if it threads onto the piece that sticks out of the t-case, has a "drop" to it, then on the other side the cable threads onto it, it's a ratio adapter.
  5. barneybasher1010
    Sep 25, 2005
    908
    PORTERVILLE CA
    it must be the ratio adapter.THANKS EVERYONE :D
