203 Transfer Case Cut and Weld???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 73CowBlazer, Jul 6, 2001.
  1. 73CowBlazer
    73CowBlazer Registered Member
    Jul 25, 2000
    13
    Houston
    The guy I usually trust on this stuff is tellig me he needs to "cut and Weld" the interanl linkage on my '73 Blazer, and I am totally confused by this. It won't shift into lock in Low or Hi and I don't see why he needs to do this??? Can anyone tell me what he is talkin about,, Grim???
  2. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    The linkage is fully adjustable and doesnt need to be cut/welded. He's smoking crack. Dont let him do it.
    Crawlin the rocks with my K5
    <A target="_blank" HREF=http://www.rockreadyk5.com>http://www.rockreadyk5.com</A>
  3. 73CowBlazer
    Jul 25, 2000
    13
    Houston
    He's talking about cutting the INTERNAL linkage, the thing that is attached to the tCase, I don't know what it's called. Is this a BOGUS deal????
  4. Waxer
    1,857
    Long Beach, CA.
    It sure sounds like it. YOu dont need to cut ANY linkage to get the thing adjusted properly. Grab a Haynes and it will tell you the procedure for adjusting the linkage the correct way.
  5. 4xmac
    4xmac Registered Member
    May 1, 2000
    82
    Calif. Oceanside
    Iam not sure what internal linkage he is talking about. On the inside you have gears and two shift forks and thats it. On the outside you have the shift lever which is mounted to the adapter and a small piece of linkage about 3" long attached from the bottom of the shift lever to the shift rails. I havent got a clue what he is talking about.
    MAC
  6. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    If you trust the guy, he's probably not a complete moron, so have him explain exactly why he wants to do this, preferably with a blow up view so you can see what's going on. You shouldn't have problems with a 203 linkage that can't be fixed externally, the shifter arms have all kinds of throw on them and should have enough to shift the differential without difficulty.
    Making the world better, one truck at a time.
    [image][/image]
    SW-ORD
