203 twin stick
Discussion in 'OffRoad Design' started by chromewontgetyouhome, Sep 20, 2004.
  1. chromewontgetyouhome
    chromewontgetyouhome Registered Member
    Aug 1, 2004
    69
    Big Island, Hawaii
    Hello,
    Im intrested in the 203 twin stick and was wondering if its a simple bolt on or if I have to get inside the gear box and modify. Thanks /forums/images/graemlins/hack.gif /forums/images/graemlins/truck.gif
  2. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Don't you mean twin stick for a 205. /forums/images/graemlins/confused.gif
    I don't think there is any way possible to twin stick a 203.
  3. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    pulled from the ORD site
    NP203 twin stick shifters: $170
    That's right, we can twin stick the 203! You get rid of the trouble prone and typically worn out factory shifter box and replace it with 2 levers for much more positive gear selection. One lever will shift the case through Hi-N-Lo and the other will control the differential lock, or on cases converted to part time, the other lever will control 2wd-4wd.
  4. thedrip
    thedrip 1/2 ton status
    Dec 13, 2003
    1,129
    Chattanooga, TN
    Twinsticking the 203 is easier than the 205. Theres no rail to modify or anything. The case literally has two different actuators coming out of the side. one for range/neutral and one for the differential lock (or 2/4wd with a part time kit). you just put a shifter to each actuator lever, and away you go. No mods to the case itself at ALL.
  5. shaun
    shaun 1/2 ton status
    Apr 22, 2003
    745
    Will there ever be a way to twin stick the 241??? /forums/images/graemlins/yikes.gif
  6. chromewontgetyouhome
    Aug 1, 2004
    69
    Big Island, Hawaii
    THanks guys, you talked me into it, gonna get one!!!!!!
  7. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Well i stand corrected. I thought he was confusing the twin stick 205 for the 203. Seems like a good way to eliminate the factory shifter that has much to be desired. /forums/images/graemlins/thumb.gif
  8. SF87K5
    SF87K5 1/2 ton status
    Oct 27, 2002
    1,105
    Stedman, North Carolina
    ORD has done it again. /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
    Wish they had pics on it, just have to wait and see I guess.
  9. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Once again, not much for me to answer here. The 203 twin looks just like the Doubler twin but with short linkage. Also very similar to the Doubler 3 stick but with only 2 sticks. It can be upgraded to a Doubler shifter easily.
