203 ?
Discussion in 'The Garage' started by 1979chevystepside, Dec 18, 2006.
  1. 1979chevystepside
    1979chevystepside Registered Member
    Feb 5, 2006
    46
    Huntsville AL
    so heres the deal. i was reading up on this huge hunk of junk that i have for a tcase and came across a couple of old threads that said this: if your truck has manual hubs and a 203 it wont move if it is free at the hubs and and not in LOC on the tcase.
    it goes on to say if it does move, then it has a Part Time kit in it.
    so heres MY question, how come my truck moves when the hubs are in the free position and not in lock mode? I know my last 203 and the one that is in there now does not have the part time kit. i also know that the hubs are working right due to when i was climbing a hill and starting spinning, only the rear spun. so does my truck just not fit into what the 203 SHOULD be doing or is this a false statement that the truck wont move if the hubs are free and not in lock?
  2. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Are you sure it is a 203 and are you sre it was not in 4 loc?
    Ira
  3. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    And are you sure it doesn't have a part time kit. I have taken two 203s out of poeples trucks to install a part time kit only to find they already have one. One of the guys got his case from a junkyard. It already had the part time kit installed.
    The reason it shouldn't move if you are still full time and have the front hubs in the free wheel position is that the transfer case basically has a differentail in it. Just like an open diff, power will follow the path of least resistance (to put it simply).
  4. 1979chevystepside
    Feb 5, 2006
    46
    Huntsville AL
    agreed but then it should also pull with the front wheels if it is locked in at the axle. right? personally i think that tcase is just sketchy to begin with mine works fine its just always seems like im going to break it. anyway either i have gotten 2 cases that i was PROMISED that it was full time 4x4 and gotten converted ones or my truck is just messed up. im pretty sure its full time because the front drive shaft spins in unlock mode driving it around with the hubs unlocked.
