203's 205's and adapters
Discussion in 'The Garage' started by 74poj, Apr 22, 2006.
  1. 74poj
    74poj Registered Member
    Apr 12, 2005
    46
    Montana
    got the typical 70's th350/203 combo. :mad: wanna swap in a 205 for obvious reasons. however, i'm having difficulty finding the th350 version of the 205. from what i've read on the net all th350's came with a 203 after 72. i've found a lot of sm465 versions, with the 10 spline input. i've also researched the cost of a 27 to 10 spline adapter and they seem to be somewhat reasonable. what seems to be unreasonable is the th350 to 205 adapter. eventually i want to do the sm465 conversion so getting the 27 to 10 adapter would have some purpose since i need the 10 for the sm465. bottom line here's my main question. will the adapter between my th350 and my 203 work with the 205? :dunno: they look pretty much the same on the truck at least. thanx
  2. nvrenuf
    Jan 7, 2002
    13,076
    246
    Mobile, Al.
    Sorry but they are different, the 203 adapter is about 1" thick whereas the 205 adapter is ~4" thick. Also the bolt pattern of the t-case face is different.
  3. BizeeB65
    BizeeB65 1/2 ton status
    Oct 12, 2005
    859
    Louisville, KY
    Keep searching buddy. It just takes patience. I finally found mine in a junkyard 60 miles away. But its gonna be worth the price. :)
  4. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    Where in CO are you?? There is a junkyard near Erie, can't remember the name tho, they had alot of 4wd's, they might have something. If you can't find any, drop me PM, I think I tripped over one yesterday in a junkyard here.
  5. JeffHK5
    JeffHK5 1/2 ton status
    Mar 16, 2005
    544
    Cincinnati
    I have owned three TH350/205 combos , they all came out of Suburbans. Don't know why that is , it just is.
    Next time your in Cincinnati, come by I'll make you a smoke'n deal on every thing you need to put a 205 in your rig.
    Jeff
  6. BizeeB65
    Oct 12, 2005
    859
    Louisville, KY
    Well, I am over in Louisville, and if my deal falls through, i will be messaging you.!
  7. JeffHK5
    Mar 16, 2005
    544
    Cincinnati
    I know this ain't the "fore sale" section but I do have a complete set-up.
    When I broke it apart to make it easier to move I did notice that the drive sleeve is about killed. I don't think I've seen one with more than 50K miles on it that wasn't worn-out. It's out of a Sub so it has a slip-shaft style rear output.
    Jeff
  8. 74poj
    Apr 12, 2005
    46
    Montana
    thanks guys! not to jack it into a for sale/parts needed thread but........i don't get out east too often and can't imagine the shipping on a whole setup.:eek1: if any of you have this part https://eshop.advanceadapters.com/commerce/catalog/product.jsp?product_id=1470&czuid=1145968551502 around, it's really what i need. i can get 10 spline 205's out here all day, cheap, and the $100-150 for the input adapter i can deal with. what just seems outrageous is the $276 they want for this guy.
  9. JeffHK5
    Mar 16, 2005
    544
    Cincinnati
    So what your looking for is a 27 spl in-put for your 205 that's currently set-up for 10 spline? And you also need a th350 to np205 adapter and coupler sleeve? The GM version of what AA is selling can be found on ebay for half the price.
    Or am I missing something?
    The "input adapter" you speak of has 10 spl. on one end and 27 spl. on the other ?
    Jeff
