205 and 208 slip?
Discussion in 'The Garage' started by WakeBoard&4X4er, Mar 1, 2004.
  1. WakeBoard&4X4er
    WakeBoard&4X4er 1/2 ton status
    Jun 29, 2000
    2,325
    Lee's Summit, Mo
    are the slip yokes the same?
  2. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    I don't think so. The 205 that had the slip was a 400 shaft, Which is usually bigger than the 208's. Atleast with the one's I've had.
  3. ColAdo82K5
    ColAdo82K5 1/2 ton status
    Feb 18, 2000
    789
    MO
    My 208 uses a CV shaft from a 400 turbo cadiallac....
    Blake
  4. WakeBoard&4X4er
    Jun 29, 2000
    2,325
    Lee's Summit, Mo
    stock? /forums/images/graemlins/doah.gif
  5. morphed86k10
    morphed86k10 1/2 ton status
    Jun 25, 2001
    463
    Reno Nevada
    I had an 84 K30 with the stock slip-yoke 205 (with a TH400), and it was directly interchangeable with the slip yoke that came stock in my 86 K10 with a 208(and SM465). I was going to swap the driveshafts when I rolled the K30, but the shaft was a bit long.
  6. ColAdo82K5
    Feb 18, 2000
    789
    MO
    It is the stock slip and CV joint....but the shaft was cut to length with the correct yoke on the rear end side.
    Blake
  7. WakeBoard&4X4er
    Jun 29, 2000
    2,325
    Lee's Summit, Mo
    the reason i am asking is i had a 91 with a 241(new 208) and the one i have know is a 73 with aa 465-205 slip i wanted to know if the spares i have would work with me 73 or not.
  8. WakeBoard&4X4er
    Jun 29, 2000
    2,325
    Lee's Summit, Mo
    what about the front d shaft.
  9. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    '73 uses a Spicer (yoke) front output while '91 uses a Saganaw (plate)
  10. WakeBoard&4X4er
    Jun 29, 2000
    2,325
    Lee's Summit, Mo
    any one want to trade a 91 for a 73 front D-shaft?
  11. morphed86k10
    Jun 25, 2001
    463
    Reno Nevada
    Is it the stock 205 from the 73? I thought slip yoke 205's were only made in 84...
