205 crossmember
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Big'nBadK5, Aug 1, 2003.
  1. Big'nBadK5
    Big'nBadK5 Registered Member
    Feb 9, 2003
    84
    Pjs, Ny
    So today i'm putting in the 465/205 in my blazer and i just got to the point that i wanna put the cross member in, i have thcross member off of the donor truck (80 k20 longbed) and the holes do not match up. any one else have this problem. and if so how an i gonna fix it? thanks. /forums/images/graemlins/thumb.gif
  2. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    I used a mid 70's crossmember on my 85 blazer when I took out the 208 out and put the 205 in. What I did was supported the tranny with a tranny jack and lowered it down a bit (everything bolted to gether). I then put the crossmember on the t-case with new bushings and jacked the tranny up so the crossmember was againsed the frame. The holes didnt line up eaither so I had to drill new holes in the frame and used grade 8 bolts with washers.
  3. Big'nBadK5
    Feb 9, 2003
    84
    Pjs, Ny
    Do you know of anything, maybe a different cross member that would allow me to just bolt everything togeather?
  4. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    Don't know of an aftermarket cross member. It would be very easy to just drill new holes.
    85K5 3/4ton,14bolt,10bolt,9"lift,35"boggers,16.5x14 welds, big horse 406SBC/700R4 /forums/images/graemlins/k5.gif /forums/images/graemlins/angryfire.gif
