205 driveshaft work on 241sye?
Discussion in 'The Garage' started by muddybuddy, Jan 29, 2006.
  1. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    hey there, im looking to go to eventually go to a 241SYE and was wondering if a stock driveshaft off a k5 with a fixed yoke 205 would work? i know it might need to be shortened a little, since the 241 would be a little longer, but it should work right?
  2. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    any thoughts?
  3. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    well if the ujoints are the same then it should work.
  4. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    ya thats what i thought. im hoping with that extra length of SYE i can use a stock driveshaft til i can afford to get a HAD one.
  5. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,073
    486
    Grand Rapids area
    Well if you have 8" springs, then you would want the extra length, no?
  6. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    i thought that 241 sye uses a flange, not a yoke like a 205 would:confused:
  7. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    yes the lil extra length will help, but it also has 14b so the pinion is longer than stock. i guess theres only 1 way to find out....ill hvae to test it for myself and report back :-)
  8. redneckdude
    redneckdude 1/2 ton status
    Feb 21, 2004
    578
    Augusta, GA
    You can get either a flange or a yoke...i think when i do mine ill do the flange so i can run the e-brake and then have a flange-mounted yoke for the driveshaft.
  9. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    i like the idea of flange so u can swap driveshafts if u break one. but then i couldnt use stock 205 driveshaft
  10. 79k20350
    Nov 22, 2004
    7,757
    Ct
    When you go had you cant use a yoke. that means if you go sye with a yoke youll have to buy the flange afterwards to run a had. really you'll wind up spending more money buying the yoke, flange and 205 driveshaft where you coulda just went with a had anyways.
  11. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    had doesnt make yoke cv's?? crap
  12. 79k20350
    Nov 22, 2004
    7,757
    Ct
    jesse might but from what i remember he doesnt but i may be wrong. shoot kidjethro a pm, hell know. thees a very good chance he may but every pic ive seen if for a flange. i prefer the flange anyway (cause there are cvs off yokes out there)
