205 Ebrake question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by chvyhs, Feb 20, 2004.
  1. chvyhs
    chvyhs 1/2 ton status
    Feb 12, 2001
    1,469
    Murrieta, California
    I was planning on doing the 205 Ebrake on my Sub after I located a mechanical caliper and the matching rotor for free. I just don't know exactly how the rotor mounts to the output shaft. I was looking at H.A. Driveline's stuff and it looks like the rotor is just sandwiched between the CV joint and the output yoke(?).
    I already have a CV joint on my driveshaft so would I just need to change the output yoke and the end of my CV joint?
  2. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    The rotor has a step in it, if I remember correctly, and the flange has to be a little longer to fit the rotor. If the flange is long enough (there are 2 sizes) then you can send the one to jesse and he can machine it, but if not you have ot buy his special flange. Give Jesse a call at HAD, he can help you out better then my fuzzy memory! /forums/images/graemlins/thumb.gif
  3. chvyhs
    Feb 12, 2001
    1,469
    Thanks /forums/images/graemlins/thumb.gif
