205 front output nut..what size?
Discussion in 'The Garage' started by supersize75k5, Sep 23, 2006.
  1. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    :1zhelp: the output nut for the front drive line, my nut is missin! so she is leaking, what size nut is that????????????????????????????
  2. Jagged
    Jagged 1 ton status
    Apr 25, 2005
    11,460
    SWVA
    I know where my nuts are... you better find your nuts ;)
  3. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    Why don't you just measure your shaft? If you get the diameter of your shaft, then you'll know how big your nut should be. Then just check the thread count. I don't know it's a standard size though, might be some specialized automotive thing. I think you'd be better off just getting one from another 205. I think that the OD of the nut is 1-1/8", either that or 1-5/16". Those are the choices, but I think the latter is for the rear. That won't tell you the shaft and thread size though...
  4. dremu
    Feb 27, 2000
    15,954
    445
    East of San Francisco
    Measuring your shaft to see how bit the nuts are?
    Wow. Only in this hobby would straight men say that to one another :haha:
    -- A
  5. supersize75k5
    Feb 3, 2004
    8,832
    4
    gilbert az
    id tried to measure a few times but I had a hard time getting a # I felt was right,
    after a couple trips I had a couple nuts from the store but none of them would work,
  6. BoondocK5
    BoondocK5 1 ton status Author
    May 13, 2006
    10,035
    63
    Salt Lake City, Utah
    I beleive 1 3/8 is correct, I ended up using a tie rod socket on it to get mine apart.
  7. pvfjr
    Feb 10, 2004
    2,425
    Oakridge, OR
    Nope. Just went out and checked on a 205 I have apart. The rear shaft is bigger than the front. 1-5/16 in the back, and 1-1/8 in the front. I measured the front shaft, and it looks like it's 3/4" fine thread (16 tpi). You'll want to get a pinch lock of you can.
    Something like on this page, just ignore the nylon insert ones though.
    http://www.fastenal.com/web/products.ex?No=10&N=999600081+1199963684+1199857973&Nty=0
  8. fatbob
    fatbob 1/2 ton status
    Jul 3, 2003
    420
    Phoenix, Az
    I tried to find a nut for a 32 spline output shaft, and found out they were 7/8 x 20 tpi. A 7/8 coause thread was like 9 tpi and a fine thread was 14 tpi, so copperstate nuts and bolts did not carry it. Now you didnt say which output you have, 10 or 30 spline, and there COULD be a difference in sizes also. So your best bet might be the dealership.
  9. pvfjr
    Feb 10, 2004
    2,425
    Oakridge, OR
    Well if he's got a 465/205, the odds are in favor of 10-spline I believe. Should be like mine.
  10. fatbob
    Jul 3, 2003
    420
    Phoenix, Az
    But this is supersize we're talking about, and he dont leave anything stock.:haha:
    So it could be anything, even a ford front output [ 32 spline]:D
  11. pvfjr
    Feb 10, 2004
    2,425
    Oakridge, OR
    Very true. And if he modified it, that would explain why he's missing a nut. :haha:
