205 front output seal
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Mudstud, Oct 16, 2002.
  1. Mudstud
    Mudstud 1/2 ton status
    May 29, 2001
    1,472
    Memphis, TN
    I replaced the seal but now the dust shield on the yoke hits the seal before the bolt on the yoke is tight. The seal is about flush with the aluminum housing. Do I need to beat it in a bit further. The blue silicone has cured all ready should I be concerned about that if I gotta hit on it somemore?/forums/images/graemlins/k5.gif
  2. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    The dust shield is not fixed, it's a tight fit and you can move it back and forth to position it, just use a screw driver or something as leverage and put it where you want.
    /forums/images/graemlins/thumb.gif
  3. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    The seal should sit about an 1/8" below the housing; I just replace both output seals.
  4. Mudstud
    May 29, 2001
    1,472
    Memphis, TN
    Thats what I wanted to hear- /forums/images/graemlins/thumb.gifthanks
