205 HD Front Outputs, Female inputs. SYE's, Input gears, ***UPDATE***.
Discussion in 'General Parts for Sale' started by dhdescender, Oct 18, 2004.
  1. dhdescender
    dhdescender 1/2 ton status
    Aug 10, 2002
    628
    Qualicum Beach, British Columbia, Canada - Eh.
    205 HD Front Outputs, Female inputs. SYE\'s, Input gears, ***UPDATE***.
    205 Slip Yoke Eliminator!
    32 spline rear output fixed yoke shaft, bearing retainer /w *new* seal, and the yoke. This will convert your slip yoke 205 to a fixed.
    $90 + Shipping.
    32 spline Ford front output. Converts your 10 or 30 spline front output to a 32 spline....BEEFY. $90 +shipping. Includes shaft, retainer & *new* seal, bearing and yoke.
    27 spline inpout gear, bearing and double female sleeve for TH350 or 700R-4. $65 +shipping.
    Ford Divorced Transfer case input gear - $65 + Shipping.
    Ford 31 spline Input gear, GREAT for dual transfer cases, as it fits in the big bore Chev cases! $65 + Shipping.
    30 spline front output. This is the later stock 205 input. Good if you fooked yours or are going from a 10 spline and want somthing with a finer spline.
    $30 + Shipping.
    SM465 -> NP203 Adaptor. No cracks, great condition. $150.
    SM465, ten spline $50.
    If your in need of somthing funky (Ford case with chev input gear) let me know, I'll try to get somthing together to save some hassle.
    I also sell big bore cases for female input gears. Inquire for stock on hand.
    I usualy ship via UPS unless otherwise requested. Currently M/O are preffered, and I will ship upon payment, at which point you will recieve the tracking #.
    ***UPDATE*** All Output kits include a new seal.
    -Kyle.
  2. dhdescender
    Aug 10, 2002
    628
    Re: 205 HD Front Outputs, Female inputs. SYE\'s, Input gears, Adaptors....
    Bump *All parts currently In Stock*
  3. dhdescender
    Aug 10, 2002
    628
    **Update**
    All 32 spline output kits Include a new seal, installed and ready to install.
    Shipping to most of the USA is usually around $22 for a front and rear kit.
  4. dhdescender
    Aug 10, 2002
    628
    Bump /forums/images/graemlins/whistling.gif
  5. aj johnson
    aj johnson 1/2 ton status
    Nov 2, 2004
    232
    Idaho Falls, Idaho
    what do I need to convert a 10 spline to a TH400 setup? whatcha charge for it? /forums/images/graemlins/waytogo.gif /forums/images/graemlins/woot.gif
  6. dhdescender
    Aug 10, 2002
    628
    Which version TH400 are you looking to convert your case to, the Shorter 1980-1985 input mated with a Figure-8 style Adaptor (also the nessesary input to use dual transfer cases), or the later 1986and up "long" input, that is found with the round pattern adaptors?
    do you require the input gear alone, or do you also need the bearing, and transmission adaptor?
    Regardless which you need, you'll either need a new case, or bore out your current case to fit the larger input bearing of the TH400.
    I have some large bore cases, and the parts you'll need to convert to a 400 setup, I just need more info on your project. Give me all the details you can, and I'll get a price back to you.
  7. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    Can you get TH350/NP205 couplers?
  8. Okiemuddog
    Okiemuddog 1/2 ton status
    Mar 3, 2003
    1,260
    Guthrie, Oklahoma
    Re: 205 HD Front Outputs, Female inputs. SYE\'s, Input gears, ***UPDATE***.
    I need a front input/bearing assembly to convert my th350 version 205 to a short 32 spline th400 for my doubler. I know you have to have the case machined, I just need the new input /forums/images/graemlins/peace.gif /forums/images/graemlins/peace.gif.
    Krennen
