205 idler shaft end play, Easy set up idea. For Rob and anyone interested
Discussion in 'The Garage' started by FWP, Feb 3, 2003.
  1. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    The trick is to make sure the spacer and shims are centered between the bearings before you start pressing the assembly together without the idler shaft to keep things centered. I used a bushing in between the press and the top bearing to keep an equal load on the top bearing. Beats the heck outta pounding the shaft in and out of the case to get the preload right /forums/images/graemlins/wink.gif
