205 in a TH350
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by HispanicPanic, Mar 30, 2001.
  1. HispanicPanic
    HispanicPanic 1/2 ton status
    Mar 21, 2001
    351
    El Paso, Texas
    will a NP205 bolt right on to a TH350 or do i have to go Advance Adapters?
    NOT ALL HISPANICS DRIVE LOW RIDERS :-)
  2. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Some of them bolted right to a TH350. In fact, that is the most common config in automatics. You just have to find one that came out from behind the TH350, manuals and TH400 205s will not work without trouble and $$$.
    Bad Dog
    85 K30 CUCV, 350 TBI, TH400, NP205, D60/C14, 4.56
    Coming soon: 4" lift, 40" tires, massive cutting, shorter wb and rear overhang.
  3. Emmettology 101
    May 9, 2000
    8,126
    FL
    One that weren't behind a th350 will require an tailshaft swap......
    HTH
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; <A target="_blank" HREF=http://emmett.coloradok5.com>http://emmett.coloradok5.com</A>
    "He who uses a winch...... Is tired of yankin!"
  4. HispanicPanic
    Mar 21, 2001
    351
    El Paso, Texas
    what im doing is im buying a 3/4 ton 78 chevy flat bed for 500.00 and im going half on it with a friend im letting him take the 14 bolt and 10 bolt and im getting the 205 and the rest of the truck which i can use for parts since i dont need the 14 bolt its not a bad deal but you see the 205 comes with a manual tranny so my ? now is how much money will i have to spend to bolt it to my 75 jimmy auto TH350 or ive also heard you can get a 205 and a 203 and make a doubler is this true thanx
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Another option, since you'll have the whole truck, is to swap the transmission and transfer case from that truck into your K5. First gear in those 4-speeds is a serious granny low crawling gear. Of course, you'll have to shift gears for yourself then. [​IMG]
  6. HispanicPanic
    Mar 21, 2001
    351
    El Paso, Texas
    Yea but i like my auto cuz of my daily driving
  7. Emmettology 101
    May 9, 2000
    8,126
    FL
    you will need to have the input shafted chnaged and get a new adapter. If you find a used adapter it will be a lot cheaper and I think thatk30guy has one for sale. The input shaft itself, I think runs about $200-300..
    Then if you cant do it, you will need to have someone install it for you...
    Mike [​IMG]
